Technical Yet another white wall grinding thread.
Discussion in 'The Hokey Ass Message Board' started by DarynCalton, Aug 13, 2014.
  1. DarynCalton
    DarynCalton
    from Stover, MO
    I searched on here and on Google and had no luck. I was wondering if anyone has ground out a set of Eldorado Legend GT tires? My truck came with them and they are like brand new. They are a raised white letter tire but I didn't know for sure if they could be ground out to white walls. Any help would be great.
  2. Haven't done that particular tire but I'm sure it'll work. Mine were raised white letter and worked great.
  3. DarynCalton
    DarynCalton
    from Stover, MO
    I think I will give it a shot next week. I will try a small area to make sure there is white underneath.
  4. jchav62
    jchav62
    All white letter tires should have a band of white underneath. You should be fine.
  5. white64
    white64
    from Maine
    I've done several sets using a 4 inch grinder with a fine flap disc and smoothed with a 220 grit on a DA sander...
    Things I've learned:
    • On some tires the white band of rubber is not a uniform circle, and sometimes you won't realize this until it's too late... :-(
    • Use no more than a fine grit on the grinder, you'll never get the deep scratches out
    • Do it with the tires fully inflated, you'll get a smoother finish
    • Clean with Bleach-white
    the tires on the '38 and the f100 were done this way: the f100 tires were white lettered, the '38 tires were a narrow whitewall
  6. kidcampbell71
    kidcampbell71
    Never knew. Nice.
  7. Hot Rod Rodney
    Hot Rod Rodney
    from USA
    I've tried grinding RWL tires into whitewalls, but the rubber eventually turns gooey and won't grind anymore.
    I suspect my grinder speed is too fast?
  8. chubbie
    chubbie
    I keep moving. Never stop, just keep going around or they will get gooey:mad::mad: never let them get hot!
