York Compressor to Air Pump Conversion
Discussion in 'The Hokey Ass Message Board' started by Scotch Buzzard King, Jun 2, 2010.
  1. I'm going to put bags on my Buick, and I want to use a York compressor to pump air into the tank. My biggest dilemma is that I don't know how to keep the compressor lubed. Any ideas?
  2. MEDDLER1
    MEDDLER1
    Im pretty sure that early ford models were pressure lubed internally.But dont hold me to it.They had a self contained system. I remember alot of my jeep buddys using them for that reason.At the time I was working at a parts house and if I remember right early 70s ford trucks were the ones I was selling them.May be check that route.
  3. crackerass54
    crackerass54
    from dallas
    I've had good luck just putting an inline oiler in front of the compressors
  4. MEDDLER1
    MEDDLER1
    Could you elaborate on that Im curious?[​IMG]
  5. shmoozo
    shmoozo
    from Media, PA
  6. jd55f100
    jd55f100
    from alabama
    York 210 compressor has its on oil bath build in holds about 10oz i put one on my 55 ...down side so far spits oil into the line..thats why you run oil trap
  7. dante81_98
    dante81_98
  8. gimpyshotrods
    gimpyshotrods
    There is a fix for that:
    http://members.cox.net/cglabe1/Air/OilFix.html
    I have one for air in the OT DD. It does not spit oil, anymore.
  9. Warpspeed
    Warpspeed
    Oh yes a truly brilliant idea......... NOT !
    Stop the oil from the compressor discharge from recirculating back to the intake port from the cylinder head of the compressor, as it was designed to do. It will then blow ALL the oil into your air bags, and eventually run the suimp in the compressor completely dry.
    Death to both your bags, and the compressor,
    Don't be a cheap skate. Air conditioning and refrigeration compressors are built for closed loop operation where all the oil always comes back to the compressor.
    Air compressors run almost dry, and are made that way.
