Drug this home from a friends place where it's been sitting for a while. It's an old dirt track car and while the body is pretty rough, the ch***is has had some traditional bolt on upgrades and it came with a bunch of extra body/patch panels, so I have enough to at least get the body solid. I've been gathering parts all summer and I have a Ford flathead V8 sitting and some odds and ends for the car already set aside. This is my first A build, so It'll be a learning experience! First step is to get everything media blasted and start working on firming up the body. Here's a few pictures for now..
Except that you put the rear tires in front, and visa versa, that is a Nice looking project you got there. I thought it was one more threat about the value of something. Looks good, keep at it.
If you can save it good for you.. We need more model A's on the road.. Will be watching the progress...
Pretty good shape for a oval track car......I've seen monkey hanger handle bars on motorcycles but never seen a monkey hanger steering wheel!...looking forward to your build!
It's as the car came, I was just happy it rolled and steered.. obviously it won't be staying like that...
You're on the right track!(no pun intended) You even have a decklid! Good luck with it-Save another "A".
Great starter kit! I'd save up and buy a set subrails and the crossmembers that hold them together Then you need a stock firewall just to align things, once the body is back to were it started you can continue on with the save. First step of any build is a good foundation. Bob
If you were close to Oklahoma I have some subrails with crossmembers I would sell cheap. You will have to do a lot of measuring.
You have a lot of metal work ahead of you but given the time and determination I am sure you can bring it back....I'll be following the build. HRP
Luckily I was able to negotiate an entire front OE cowl with a good fire and dash and some of the missing patch panels. Subrails and crossmembers are definitely going to be one of my first purchases just to get the body from flopping all around! Sure is. I've been playing with German cars since I was 16-17 until the Hot Rod/Kustom Bug bit me and I have been splitting my time between the two worlds. I still have a bunch, whole different world but they're fun as hell to drive! That one isn't a track car, more of a fun cruiser. It's the only running, driving, Mk1 VW with a VW V5 engine in it. Runs really well, was saved off of the top of a s**** pile a number of years back.
good luck with the project. I used to work at Eastwood when it was in Malvern. Good people to work with and for!
............more than I started with! 2 1/2 years later and my metalwork is nearly complete. Would do it again in a heartbeat. The search for parts is part of the challenge. And don't worry about the body flopping around, it'll all tighten up at the completion. -Ron
Been busy gathering parts over the spring and summer and I'm finally about ready to start turning this mess of parts into something. I found some Edelbrock heads that were sitting on an engine behind our Chicago retail store when I was out for World of Wheels this past spring and smuggled them home in my carry-on luggage (that had security scratching their heads!) Need to find an intake next for the engine and trans I've got stashed away. Also found a '34 Chevy dash at a local auction that I think will flow well with the inside of the car. Surprised how well it fit just clamping it into the car. I plan to make a new gauge panel to fit some old gauges I've got sitting around. I decided to tear down the ch***is to see what kind of mess was hiding underneath and it was a bit scary how badly modified it was over the years. I could flex areas of the ch***is by hand that they had clearanced to fit different things over the years and the entire ch***is was quite tweaked. I decided to tear it all down and keep a few things and sell the rest off to someone else and build a new ch***is for the car. This led to an excuse of building a ch***is table to build up off of. I went to the local s**** yard and bought all of my supplies and we did a little video on the build-up of the table. I ordered some tubing and I've begun laying out some parts to get an idea of how everything is going to jive. I'm planning to sweep the front a bit and Z the rear. Been reading a lot of other threads and saving pics of cars I've dug over the years to get inspiration for how I want the car to sit. I also got an OE deuce grill shell that was already modified for an A years ago, it has some filler in it, but its solid and can still be repaired. I tore down a good '41 rear I had sitting around and the guys over at Posies are sending me new front and rear springs to begin with. Hoping to get some tires this weekend at the Macungie Wheels of Time show and find some 16" wire wheels to mount them on, then I can start messing with stuff. More to come soon.
