Projects You Guys Cut Yourself as Much as I do ????
Discussion in 'The Hokey Ass Message Board' started by Hdonlybob, Mar 1, 2011.
  1. wheel28
    wheel28
    Who needs a vin when you just add a little DNA identification.
  2. rebelrat
    rebelrat
    Slipped on oil today and punched the ground on the way down !!
  3. mixedupamx
    mixedupamx
    2 weeks ago as a matter of fact. same kind of deal, die grinder with a carbide burr = sliver in the eye even with a good face shield. OH! and 2 days ago, angle grinder with cut off wheel to the knuckle. not much blood and no stiches but "someone" in my garage was cussing up a storm!:D
  4. merf
    merf
    from new joisey
    I'm convinced my hands hate each other, my right hand is always trying to kill my left with screwdrivers,hammers,razor knives etc.
  5. cheveey57
    cheveey57
    Blood.....Sweat......&.......Gears
  6. Paper towels and masking tape are your friend, always in the garage.
  7. badlefihand
    badlefihand
    Just did a check,three cuts on right hand,two on the left. Just average.
  8. seb fontana
    seb fontana
    from ct
    YOU BETCHA...At least a bruise or s****e...
  9. TrannyMan
    TrannyMan
    Super Glue..........That's my cure for cuts.
    I didn't believe it either, but first time I tried it the cut was healed in three days and didn't get red and sore.
    Plain old superglue, cover the cut up, keep it covered.
  10. phat rat
    phat rat
    Fold the sticky side of the tape back over on itself a little bit so it doesn't stick to the cut wrap as much as needed. No sense bulking it up with towels or rags.
  11. Abomb
    Abomb
    I think I have magnetic eyes too.....I've had it drilled out, removed by scalpel...etc.....it really ****s about an hour after you leave the hospital, that's when the pain starts....what's cool though, is in the bright sun, you can remember the good times by the spots...
  12. cavemag
    cavemag
    Just enough to be annoying. I did slip a ratchet once and my knuckle has a nice scar to show for that.
  13. 39 Ford
    39 Ford
    I bleed every time I work on something, often have no idea how I cut, s****ed or otherwise hurt myself!
  14. ChromePlaterJosh
    ChromePlaterJosh
    That made me laugh. So true, except with me my left hand is after the right.
    I get my tet**** shots caught up when I go to the ER. It works out.
  15. pecdaddy
    pecdaddy
    i like super glue to close em up when your done for the day.
  16. reefer
    reefer
    All joking aside be watchful with metal cuts.I met a local refrigeration engineer who had his arm amputated at the shoulder joint because of a cut on his thumb went bad.It was before you could buy factory made gallows brackets for haning the condensing units and he used to make his own from angle iron...he cut the angle iron in his power saw and sliced his thumb on the burr.He just wiped it off and ignored it...that evening it started swelling and his forearm was aching..the hospital sent him home with pain killers...next day his arm was wrecking him and he went back...as he was waiting his turn to see a medic a p***ing consultant saw him and spotted the trouble right away...he was on his way home and immediatley turned round and got the guy into theatre and took his arm off..and saved his life.
    I belive br*** splinters are the most dangerous for some reason.
  17. Troyz
    Troyz
    Ya, it's like a horror movie sometimes. I had a cutting wheel explode and cut through my glove and most of my finger this weekend. as for dressing wounds in the shop, I usually poor some beer over it, then wrap it with a blue paper towel, then blacktape the **** out of it, then drink the rest of the beer for pain relief. ;)
  18. peter johnson
    peter johnson
    I lose a knuckle every time i change a flexplate?
  19. BenderJ
    BenderJ
    from Detroit
    :D
    Sooo true!!
    It seems like now matter what I do, I end up s****ing a finger/knuckle to the point where the skin is still attached at one end, but it's bleeding like an son of a gun...
    Stiches are for girls. :)
  20. 73super
    73super
    Those duct tape bandages work well. Believe me.. I'm not only shedding blood on my cars, but I'm a wood carver as well... enough said. :rolleyes:
  21. Merlin
    Merlin
    from Inman, SC
    I usually keep band aids in my pocket but when I'm out paper towels and electrical tape do the trick.
  22. oldfart36
    oldfart36
    I would have type a responce sooner, but it's hard to without fingers:eek:
  23. bobss396
    bobss396
    The old cloth electrical tape was the best. Wrap a napkin around it, 3 rounds of tape and back to work!
    I do more machine shop work lately and got snagged on a 17-4PH stainless steel chip the other day, small cut on the back of a knuckle but bled for a while. I was into a run of parts so all I could do was keep dabbing it on the rag hanging out of my pocket.
    I do get a tet**** shot once in a while just in case.
    Bob
  24. Keep your pants on and you wont be cutting the wood. :D
  25. 1971BB427
    1971BB427
    from Oregon
    I've gtten so used to wearing gloves at work that I wear them working on the car all the time. I use the Kevlar gloves that are very thin, but cut resistance is very high. Before I retired the safety guy gave me a bunch of them, so I've got a good stock pile.
    My hands rarely have any cuts, unless I'm doing something in the house and not on the car. I still forget the gloves sometimes!
  26. 343w
    343w
    The worst one for me was dropping my 40 tudor body off the jack onto my left hand, it almost cost me my left thumb. They sewed it up with 47 stiches and it healed in about a month. Gloves are a pain, but they do prevent alot of minor screw-ups! Safty gl***es are a must to keep me from going to thr Eye Foundation in the middle of the night, isn't it funny how you find-out you have steel in your eye when you lay down to sleep! NOT...
  27. Fedcospeed
    Fedcospeed
    After 125 plus stiches back in 79 from a 10" grinder I try alot harder with sanders grinders and sharp things in general.
  28. i think the coveralls the old mechanic use to wear was body armor....the 37 has so many sharp points on it i bleed just looking at it....
  29. The Shocker
    The Shocker
    Im Hell with cutoff wheels and wire brushes (the rigid ones that feel like spears when they stick in your skin ) on grinders .I heal up well ,but have a scar on every fingers and knuckle seems like .I cut the end of my thumb with a cutoff wheel on an angle grinder last summer .I cut it all the way to the bone and split the nail in half. Super glue and electrical tape work wonders .I have lost everyone of my finger nails at one time or another and a few of them twice or more .I guess this stuff comes with the territory ...
  30. small daily sacrifices to the shop gods keep the big ones from hapening
