Technical You know those 50s pedals that go through the floor?
Discussion in 'The Hokey Ass Message Board' started by tin_indians, Apr 11, 2014.
  1. tin_indians
    tin_indians
    :confused: Anyone have any suggestions on what to use for gasket material that wraps around the pedal shafts where they p*** through the floor?
    My old ones seemed to be made of felt and felt like were impregnated with wax. Of course they broke into pieces when I took them off the pedals and STUPIDLY I threw them away.
  2. Left field & Quick off the top of my head- I'd grab a 300gsm (metric) weight 100% cotton watercolour paper sheet form an art supply store, cut it into size, slit, grease & layer it. Would not be fireproof though. And labour intensive too.
    There must be a better way.
  3. indyjps
    indyjps
    Wouldn't rubber sheeting work?
    Ask a local roofer if you can buy a few feet off of a roll of rubber roofing, if they've ever done a rubber flat roof they should have a partial roll laying around. Its a pretty common roof for residential on old porches, home depot may sell it by the foot?
  4. Erics53
    Erics53
    from Ohio
    National Chevy might be worth a shot. These fit 49-54 Chevy P***enger cars.
    Accelerator Shaft Floor Seal Set #783- 2 cork and 1 felt - $6
    Clutch and Brake Shaft Seal Set #785 - 2 felt pieces - $8
  5. Rusty O'Toole
    Rusty O'Toole
    Originally they had a thick piece of felt that went over the pedal, it only sealed when the pedal was up. Or, some had a kind of rubber bellows seal.
    A square of felt carpet underlay or some kind of tough foam rubber. It fits over the pedal and goes up and down with it.
  6. Tudorp
    Tudorp
    I've known guys that made bushings from rawhide leather that seemed to work very well..
  7. HOTRODPRIMER
    HOTRODPRIMER
    I am defiantly old school,I use strips of inner tube on both sides of the the pedals.
    Seals out heat and water. HRP
  8. pasadenahotrod
    pasadenahotrod
    from Texas
    There are moulded rubber seals available for early Fords and a moulded bellows type seal for early Mopar products.
  9. A s**** of EPDM roofing works well.
  10. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    I've used MANY inne tubes fo such stuff.
    On my unibody I recently replaced the "seal" for the cowl vents. Went to the hobby store and got some new fangled foam/felt type stuf, works better than the old seals ever dreamed of and it was a whopping 99 cents for a sheet
  11. tommy
    tommy
    bingo! Always keep a leaky innertube in stock for just these occasions.
  12. HOTRODPRIMER
    HOTRODPRIMER
    Yeah Tommy,,and you can't get much more traditional than a inner tube!:D HRP
  13. tommy
    tommy
    You mean you don't need a web site to fix it?:D They make excellent gaskets for painted parts that may chip.
  14. vtwhead
    vtwhead
    I too use a piece of a "leaky old inner tube" that I keep in stock. Has always worked for me. cheap and easy!
  15. jazz1
    jazz1
  16. fiftyv8
    fiftyv8
    from CO & WA
