you know what my problem is ???
Discussion in 'The Hokey Ass Message Board' started by larry k, Feb 28, 2012.
  1. larry k
    larry k
    i have a 350 chevy that has a miss when it's cold, but goes away when it gets warm ?? did the compresson test, all ok, leak down test no leaking valves,new tune up & wires, what's left to be wrong ? somebody gotta know , so lets have it, tell what my problem is , i can take it !!!:cool:
  2. Toecutter
    Toecutter
    Fuel leaking down into the cylinders overnight. Which in turn fouls out a spark plug. Will miss when it's cold until the plugs build heat and burn off the excess fuel. Seen it happen with Quadrajet carbs.
  3. brigrat
    brigrat
    from Wa.St.
    Carb
    Choke
    Plugs
    Plug wires
    Points?
    Rotor
    Dizzy cap
    Lean
    Rich
  4. Ryan
    Ryan
    ADMINISTRATOR
    I've had this one happen before...
  5. larry k
    larry k
    "hey" where are all the small block chevy guys,???somebody has to have an idea as to what is happening to my engine ? somebody has to have seen this movie before ? so give me some info ,,, man:cool:
  6. Wagonmaster2
    Wagonmaster2
    I'd look into ignition resistance. A bad wire, plug, or cracked cap or rotor, etc.
  7. Is it one cylinder or random missfire when its cold ?
    Cold = damp too in most cases, id check your ignition system first.
    Maybe a bit rich/lean when on the choke.
    If you suspect fuel loading up while it sits, that should be easy enough to find excess fuel in the intake tract on a cold engine.
  8. Is it one cylinder or random missfire when its cold ?
  9. 87notch
    87notch
    from kentucky
    Its a Chevy . Problem identified.
  10. Jimv
    Jimv
    Ever get up in the morning and ya walk a little wobblie? Same thing! lol.
    Just sounds like some clearances are a little loose & everything tightens up when warm. can also be something to do with resistor plugs & wires
    JimV
  11. Ryan
    Ryan
    ADMINISTRATOR
    We did. What are we? Chopped liver?
  12. jb39chev
    jb39chev
    from Conroe,TX.
    Had the same problem on my 327, after a lot of head scratching,trying this and that, new plug wires solved it.
  13. donsz
    donsz
    As the replies show, it could be a myriad of things. To add another possibility, on one of my 350's, it often got condensation inside the distributor cap in the AM. Apparently a common problem, some people used to enclose the cap in a plastic baggie to mitigate the problem.
  14. unkledaddy
    unkledaddy
    You've already gotten enough ideas to keep you busy for awhile. There is
    no 'Silver Bullet' in your case.
    So, get to work and don't be so demanding.
  15. bobwop
    bobwop
    from Arley, AL
    hydraulic lifter not pumping up until the oil gets warm (thin).
    what viscosity oil are you using?
  16. check your tire pressures....
  17. terryble
    terryble
    from canada
    I notice in your photo your Ford is in their usual spot on a trailer or on a hook. You started it!
  18. Happydaze
    Happydaze
    Choke not functioning properly? - either not at all or opening up too early? If automatic, could be anything, if manual, operator error?
    I think these kind of problems aren't the preserve of Chevys only!
    Chris
  19. Check for a sloppy bushing on the bottom of the distributer shaft. Sloppy when cold then everything swells when it warms up. Eventually it will eat a distributer gear, it will be 15 degrees out and if you are lucky your wife will back up though rush hour traffic to give you a tow to the house. ;)
  20. CJS
    CJS
    Are you loosing any coolant lately? It sounds like coolant getting in a cylinder to me. I hope not but the symptoms look that way. If it is a fresh build you may only need to torque the heads again . Do you see any white smoke out the tail pipe on startup? You could find a radiator presure pump and preasurize the coolant system after a good warm up, pull the plugs and then crank the engine over after a few hours. I usually put a piece of cardboard in front of the spark plug holes and look for coolant after cranking.
  21. old soul
    old soul
    from oswego NY
    Your not that wise are you????
  22. Harry o
    Harry o
    from Georgia
    my 55 chevy was doing the same thing ... Put new plugs in and that fixed it ... The gas were getting now is causing problems like that ...
  23. Hey dont blame the General, blame the previous owner for never doing proper maintennance.
  24. BOWTIE BROWN
    BOWTIE BROWN
    How rude.(WAIT TIL YOUR ford HAS SHIT TO BED)
    B.B.
  25. chaos10meter
    chaos10meter
    from PA.
    What kind of choke do you have ?
  26. Don's Hot Rods
    Don's Hot Rods
    from florida
    Yeah, 20 guys jumped in and gave you some solid suggestions, what more can you expect from an internet diagnosis ? And they didn't even charge you $ 95 per hour ! :D
    Don
  27. jstanotheidiot
    jstanotheidiot
    Spit coffee on key board on that one
  28. brigrat
    brigrat
    from Wa.St.
    X2, un-subscribed......................
  29. I have read and reread the thread and I have finally figured out what you problem is. I know you can probably take it, but if I tell you what your problem is someone will be offended, if you catch my drift.
  30. Atwater Mike
    Atwater Mike
    Thank the gods of all things mechanical that I am exempt from seeking help from such a diverse wealth of cosmic intellect.
