You want DRAMA? Then READ THIS!
Discussion in 'The Hokey Ass Message Board' started by Django, Dec 22, 2003.
  1. Django
    Django
    from Chicago
    I'm showing my newly polished finned valve covers for my 289 to a buddy and he asks " Are they magnesium?" Proudly I say YES! So he proceeds to tell me that they are junk and I've got 3x the money in them than they are actually worth.
    Huh?
    So magnesium valve covers are bad? They warp and leak like a sieve? Fuck. Now what? I got too much in them to not keep them and they look bitchin'! I love them. Square shape, not the normal SBF valve cover shape.
    How can I make them work without leaking? Silicone the shit out of them??
    Help! This DRAMA is killing me!
  2. Roothawg
    Roothawg
    I use the 3M weather strip adhesive on cork gaskets. Glue em to the vc and leave the other side dry. I would try em first. I use a lot of stuff other people call junk and never have a problem.
  3. yorgatron
    yorgatron
    has your friend actually ever used a set of magnesium valve covers? probably an old wives tale.
  4. Ryan
    Ryan
    ADMINISTRATOR
    Uhhh... I've used mag valve covers for years and have never had a problem. Sounds to me like the guy tightens em down too much.
  5. Bass
    Bass
    from Dallas, TX
    Hmmm...I believe new Corvettes come from the factory with magnesium valve covers these days.
    If you use a good gasket I don't know why they wouldn't work at least as well as aluminum. (?) I think most people that swear that all alloy valve covers leak have just had a bad experience with a warped set of valve covers.
    I'd definitely suggest that you try them before you give up on them...they sound really cool. Got a pic?
  6. Django
    Django
    from Chicago
    I have a huge amount of respect for him, and without his help, my car would still be many months away from roadworthiness. He did say that you have to be careful torquing them down because the magnesium will crack because it is thick and more brittle than aluminum.
    The 3M sounds interesting. Ryan, did you do anything special to seal yours?
  7. Roothawg
    Roothawg
    No one likes the Cal Customs I use because they have a small sealing area. A lot of old timers hate em because of this. I started using the "gorilla snot" trick and it seals every time.
  8. Django
    Django
    from Chicago
    Maybe he did have a bad set at one time. He was'nt very complimentary regarding the quality of mag in his experience.
    I don't have a recent pic, but this is them before they were stripped and polished. Made by Keystone. Looks to me like they were never on a car...
  9. cleatus
    cleatus
    from Sacramento
    A lot of performance motorcycles use magnesium for cases and side covers. I don't think they would if they were prone to "warp and leak like a sieve".
    It don't hurt to try them, they sure look good.
    Are they for the 36?
  10. KIRK!
    KIRK!
    Those are badass and seem to have a ton of sea; space. Try a layered construction gasket with even torquing.
  11. Paul
    Paul
    Editor
    being a Chevy guy I can only assume that what your friend was trying to say was that it's a waste of time to put them on a Ford [​IMG]
    'never used a mag valve cover but, for aluminum I always use Permagasket 2 on both sides of a cork gasket for a leak free cover.
    Paul
  12. Deuce Rails
    Deuce Rails
    [ QUOTE ]
    [/ QUOTE ]
    I'd swap out the buddy.
  13. Django
    Django
    from Chicago
    Maybe he was right Paul! This 289 in the '36 and the 302 in the wagon are simultaneously the first sbf motors I've ever had. It's been a learning experience!
    Does polished magnesium oxidize faster than aluminum?
  14. Fat Hack
    Fat Hack
    from Detroit
    Yes, the magnesium will oxidize...or "dull" faster than aluminum.
    Come to think of it, your buddy's right...they're JUNK...I'll give ya five bucks for 'em! [​IMG]
    (Way cool covers....some of the neatest SBF ones I've seen yet!) [​IMG]
  15. cleatus
    cleatus
    from Sacramento
    "Does polished magnesium oxidize faster than aluminum?"
    I once paid a metal finishing place to polish a set of magnesium fork legs for me. He told me they would turn black almost overnight if I did not clear coat them right away. I figured "yeah-right." Sure enough, they did turn gray pretty quick. I buffed them back out with Mothers and then sprayed them clear and they lasted through years of abuse.
  16. Unkl Ian
    Unkl Ian
    I think the factories don't even use gaskets any more.Everything is done with high temperature silicone sealer.Just try and get those Fuckers off. [​IMG]
    Spring for some quality aftermarket gaskets,glue them to the rocker cover.
    Do not overtighten.
    Or I'll give you $10 for them.You pay the shipping. [​IMG]
  17. Django
    Django
    from Chicago
    Ten whole dollars? Do I hear $10.50? [​IMG]
    Sounds like I'll be ok then, thankfully. I wonder if this is a case where Zoopseal would be worth the price, so they stay nice.
    OPINION POLL: Should I scrap the plans to use my caddy air cleaner and stick with a chrome or finned air cleaner to better match the valve covers? I have also considered changing the color from green to silver to match the area inside the fins. Motor will be green (at least this week [​IMG] ) Either way, I'm sanding the striping off and starting over.
  18. I think your friend is confusing them with old magnesium wheels that used to leak air if you didn't run tubes!Just my opinion.
  19. Those look real good to me- they 'll work fine....use a 1/4" ratchet to tighten them......so wont break em....snug is good ....also the new Dodge Viper runs Magnesium valve covers- I have one......[valve cover that is [​IMG]]
  20. Flat Ernie
    Flat Ernie
    Tech Editor
    [ QUOTE ]
    [/ QUOTE ]
    Roothawg nailed it - I love cork gaskets! Glue 'em on with 3M gorilla snot and stick 'em on - I like to use vaseline or even wheel bearing grease instead of dry because that way the cork slides just a bit as you tighten it down.
    I do the same on the intakes - I gorilla snot the cork end pieces to the block & coat 'em with a thin layer of vaseline or grease. Bolt the intakes down & they never leak & never squeeze out.
    RTV/Silicone is for pussies who can't make paper gaskets work like god intended!
  21. Morrisman
    Morrisman
    from England
    It's pretty hard to keep a shine on magnesium, so best send them over the pond to me [​IMG]
    Use a smear of quality silicone sealant on the gaskets, after wiping totally clean with solvent all surfaces involved, and you'll have a job getting the gasket off again. And they'll never leak a drop of oil.
    Paul
    ps. Did I mention, you'll have a hard time keeping a shine on 'em, so best......... [​IMG]
  22. Bruce Lancaster
    Bruce Lancaster
    Some Corvettes about 1987 or so had magnesium cuovers. Others had the same design in die cast. I don't know when the change was or if it was because of a problem.
    I believe the ones I have seen were painted on the inside--probably porosity insurance, or perhaps to protect then from acidic vapors and impurities.
  23. SKR8PN
    SKR8PN
    [ QUOTE ]
    [/ QUOTE ]
    God was having a bad hair day when he invented PAPER gaskets.......
    So he invented RTV to make up for it.......... [​IMG] [​IMG]
  24. mr.midnite
    mr.midnite
    how did you come to the conclusion that they are magnesium? Coming from Keystone and the photo of them plated I would suspect they are zinc diecast
  25. HOTRODPRIMER
    HOTRODPRIMER
    Those valve covers are nothing but junk,,,,,,,,,Send them to me where they can be properly be destroyed. [​IMG] [​IMG]
    I have had a set on my 65 ford truck for over 20 years and only used cork gaskets and black sealent,,,,,they do look like crap now but have never experienced any oil loss problems. HRP
  26. alchemy
    alchemy
    I think Mr. Midnite is on to something. I bet they're zinc (potmetal) too.
    alchemy
  27. Farmer
    Farmer
    those are rad man! just take em to a friend or someone who has a nice big belt sander, or similiar sander and make sure the bottoms are perfectly flat and even first. You prolly already did that though...anyway, those are so cool lookin, i'd run the risk and try to run them anyway! Do it man do it! (or send them to me and i'll burn them for entertainment next time I go surf in the morning...cool beach fire) [​IMG]
  28. old beet
    old beet
    BINGO..........OLDBEET
  29. zman
    zman
    from Garner, NC
    They're cool, run 'em. I doubt you'll have a problem getting them to seal. Just put a straight edge on the bottom to check that they're not warped first.
  30. Django
    Django
    from Chicago
    The place I had them polished thought they were mag. You think they're zinc? Would that be good or bad?
