Projects Your dream engine build...
Discussion in 'The Hokey Ass Message Board' started by lostviking, Dec 17, 2021.
  1. hipojoe
    hipojoe
    Theres DADS dream engine and mine. Cant swing a Cammer yet, so next best thing. DSCF0023.JPG
  2. hipojoe
    hipojoe
  3. hipojoe
    hipojoe
  4. RmK57
    RmK57
    Dare to dream hipjoe, you can have that cammer, it's a dream!
    chryslerfan55, squirrel and mad mikey like this.
  5. 327Eric
    327Eric
    What I have often contemplated is a 283, full roller , ported double humps, with every trick done to reduce friction and windage, with a Paxton or two, or even twin turbos, and look for 350 to 400 horsepower. This is something an enterprising hot rodder, likely with an engineering degree, or extensive engine and aeronautics background could have done around 1964.
    chryslerfan55 and Tickety Boo like this.
  6. hotrodjack33
    hotrodjack33
    Well, as long as we are dreaming BIG...and of course, a Nash Metropolitan to put it in;)
  7. fastcar1953
    fastcar1953
  8. saltflats
    saltflats
    from Missouri
    I have hand my hand some peoples dream engines. :)
    Tickety Boo and mad mikey like this.
  9. 26 T Ford RPU
    26 T Ford RPU
    Back in the early 80,s i worked building V-8's and found the 301/302 Chev's to be very cool and dreamed of building one for myself, did it then waited 32 years to put it in something.
    Now i'm dreaming of building my 46 Jeep 4 motor to power my Belly Tank. JW
  10. Dean Lowe
    Dean Lowe
    I have a dream, or more like a fantasy, I would convince Steve Hill to sell me back the red car. I know where I could remove a good 400 lbs. Then I would build one of these and bolt it up to a 2 speed glide. Then go out and run some low 8's with it, still full fendered. Full 1/4 mile, like a drag race is supposed to be, no *********** 1/8 mile. That little red Model A still wants to race, and so do I !
  11. wicarnut
    wicarnut
    I think a V8 Ford 4 cam Indy car engine with the heads turned around as shown, ran these in champ dirt cars would be "Killer" in a 32 Ford Roadster. This would be my ultimate Roadster engine. 4-cam Ford.jpg
  12. jetnow1
    jetnow1
    from CT
    At this point in my life I do not feel the need for a blown big block or a Cammer or Hemi. A rebuild of the 327/350
    horse I have had for the last 45 years would make me happy. It is a very tired but original bore block.
  13. willys36
    willys36
    My dream was/is my ’52 331 hemi. I bought it as a 16 yr old in ’64. I was literally a pile of parts in a basket but it is a HEMI!! I built it stock with a J C Whitney “3/4” cam (I still have no idea what its specs are!) and a homemade tunnel ram with a Rochester 4-Jet carb. I modified the long bellhousing bottom half to move the starter to the p***enger side ‘cause it interfered with the Corvair steering gear on the Willys frame. Have been upgrading it for the past 55 or so years.
    First I added a Holley 3bbl carb. Added 600cfm sized aluminum inserts to the primaries to make it streetable in about ’70 but still had the tunnel ram. Tore down the car in ’72 and didn’t get back to it ‘til about ’94. Added a modified 354 iron manifold and had it bored 1/8” over by Ernie Hashim in Bakersfield CA. Ernie found a couple sets of stock 354 pistons made a good set of those and balanced the whole thing.
    Sometime in the late 90s I added a 340 Chrysler electronic distributor and MSD5 module. I also cut off the water pump from the cast iron timing chain cover and added a 4" stainless industrial water pump mounted like an alternator.
    Just this year I did some major mods; biggest one is I got rid of the small round-port 331 heads and added big port, big valve truck heads. That allowed me to add a set of large tube fender dump headers replacing the small tube gl***-pak ones I had run for 20 or 30 years. You can now see my Dual Range Hydramatic and ladder bars hanging down. At the same time I got rid of the stock cast aluminum Chrysler oil filter can and adapted a small spin-on filter adaptor. Finally added a set of marine valve covers with the adjustable rocker bumps. That is strictly a vanity add, non- functional.
    Engine is still going strong and is still my dream engine.
    First build. Lucky it ran!
    Moved the starter to p***enger side. Welded new steel plate starter mount there.
    Added the 3bbl
    Modified the 354 manifold to take the huge 3bbl.
    Added electronic ignition
    Added the remote water pump, not much room in front for the stock water pump in a Willys!
    Ran these gl*** pack headers for many tears but they hid all the good stuff under the car.
    Truck heads allowed fender dump headers. I built mufflers into the 5" collectors. Work great.
    Got rid of canister filter.
    Much better look!
  14. 57 Fargo
    57 Fargo
    Hands down dream engine is an early Hemi. Preferably with a 6-71.
    Stay tuned.
    mad mikey and Desoto291Hemi like this.
  15. MeanGene427
    MeanGene427
    from Napa
    505 ci 427 with Dove PIE heads that have the tiny Glidden chambers, Cleveland tunnel ram on an adapter plate, .780 solid roller. Have most of the parts, just need some time. The 454 ci high compression with Crower rods will come first. That 330/600 cam is the King of the ****nasty idles, eh?
  16. DDDenny
    I also have an L79, a .040 over Nova block, most of it is NOS except for the block.
    Built it in the late 80's, still never fired.
  17. Hollywood-East
    Hollywood-East
    That is a Great/Beautiful engine!!
    mad mikey likes this.
  18. chevy57dude
    chevy57dude
    To stay pre 1965, a blown 409 would do it!
    Chavezk21, brigrat, swade41 and 8 others like this.
  19. 56don
    56don
    Had it idling in my back yard one day and a kid from up the street several houses away came running down to my house. He said he just had to find out what that wicked sounding car was.
    Randall, mad mikey, loudbang and 2 others like this.
  20. bchctybob
    bchctybob
    Willys36, is that an old Drag Machine adapter I see in there? That place (and Irv) was amazing, nothing he couldn’t do. And like all good old shops, everywhere you looked there was something interesting that he cast, machined, welded, or otherwise modified.
    mad mikey, chryslerfan55 and loudbang like this.
  21. 61cad
    61cad
  22. Taboo56Chevy
    Taboo56Chevy
    I've always wanted this motor in my 33 Pickup. Been hooked on that look ever since I saw the Hot Rod cover with it on display.
  23. Marty Strode
    Marty Strode
    I guess I lived the dream in the 80's, and didn't know it ! 2012-08-31 121849.jpg 2014-03-27 124010.jpg
  24. Mr48chev
    I guess for the time being I'll have to say the flathead I have because I always wanted a tricked out flathead but never gave much thought to its internals except for the cam. I've been collecting pieces for years for it. I'd have to win a powerball to afford to really do up the insides with all the goodies beyond a good ring, bearing and valve job to go with the cam. I only lack carb kits and distributor and plug wires for the outside.
    I've got a little OT dohc banger that I want to build but to do it the way I want will probably cost about the same as what that blown hemi that Marty showed dollar wise without counting inflation. Half the trick parts come from OZ and are hell for expensive.
  25. MeanGene427
    MeanGene427
    from Napa
    In '78 I lit up the 14:1 427 in the Galaxie, with the .660 DeLong cam and Milodon gear drive, uncorked in the garage. My roommate came running out the door pulling up his pants, he had been on the ****per, and the beastie was shaking the pictures off the walls
  26. partsdawg
    partsdawg
    from Minnesota
    1957 Rambler 327 or a 1958 Plymouth 350 just so I can spend all day at a car listening to the “experts” tell me those engines never existed.
  27. HOTRODNORSKIE
    HOTRODNORSKIE
    I have a 303 Olds,312 Yblock,292 Yblock and a nasty *** 390. I would not say no to a 427 cammer. Had a guy at back to the 50'S fire one up in his 63 Galaxie instant wood .
  28. bchctybob
    bchctybob
    In the past I dreamed of building one of my 392 Hemis into a nitro burning cacklefest motor to start up occasionally in the doorway of my shop and eventually use to partner with someone in a cackle car. I have some of the parts but I’m not sure I want to put any more money into it.
    mad mikey, chevy57dude and rod1 like this.
  29. I have this already…
    Mooneyham Blown 409 Stroker….
    And I also have this….
    Howard-Arias 12 Port Jimmy in my OT Bonneville race car….
    What do I dream of? A 377 CI SBC with a tunnel ram, dual 660 center squirters, 2.02 heads, .600” lift cam, revs like a DZ, pulls like a LS-6!
