Projects Your next $100.00 investment
Discussion in 'The Hokey Ass Message Board' started by The37Kid, Mar 26, 2013.
  1. The37Kid
    The37Kid
    So what is next on your "To Buy" list for $100.00? Me, I'm buying a quart of red PPG epoxy primer, may have enough left over for a coffee. Bob
  2. Half a rebuilt master cylinder.
  3. tjet
    tjet
  4. 1/6th of a restored 54 Hudson steering wheel for my Tudor.
  5. knotttty
    knotttty
  6. sko_ford
    sko_ford
    A couple sheets of 18ga
  7. walter
    walter
    A down payment on some high build primer!
    Walter
  8. 56premiere
    56premiere
    Well it will probably tak 200 , but it has to be a rebuild on my dampener pulley. 368 Lincoln. Jack
  9. Cowtown Speed Shop
    Cowtown Speed Shop
    from KC
    Gezz, $100.00 will barely fill the tank so I can go out looking for something cool to buy.
  10. Scott F.
    Scott F.
    Brake lines and fittings and hoses so that I can wrap up my brake project so I can weld in the floors I already have. Then put another hundred with what ever was left over and get some carpet to cover my ****py welds.
  11. chiro
    chiro
    Front perch pins with shock mounts for my AV8 project and tie rod and panhard for same project. That's probably a bit more, so let's say I'm good for the next two installments of the $100.00 shot.
    Andy
  12. partsdawg
    partsdawg
    from Minnesota
    Half will go to renew my membership here.
  13. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Fuel.
    In two $50.00 installment payments.
  14. BISHOP
    BISHOP
  15. I never put epoxy in my coffee. :D
    I just invested 100 bucks in brakes. But I would have much ruther spent it on paint. You're way ahead of me here.
  16. pbr40
    pbr40
    from NW Indiana
    2/3 of the 2 new teeth I need for my grille
  17. a S-10 frame for my next hot rod project
  18. theHIGHLANDER
    theHIGHLANDER
    Gasoline, a swap space, and maybe a breakfast. $100 doesn't go far these days. Used to do all that for $25!
  19. damagedduck
    damagedduck
    from Greeley Co
    final payment on my engine & trans,
  20. Molonewolf
    Molonewolf
    Bearings in the 9" rear end.
  21. brandon
    brandon
    u joint & 2 pistons to fix my coupe....then a motor swap...............again:rolleyes::eek::D putting the old truck motor back in
  22. slowmotion
    slowmotion
    One of them fancy corded trouble-lights on a retractable reel. Everytime I get my beat up ancient junker out, a cuss fest soon follows. It's earned it's retirement.
  23. TinShed
    TinShed
  24. Speed~On
    Speed~On
    RediRad cl***ic car radio adapter lets you listen to MP3/Satellite/iPod/CD players through your AM, factory-original Radio.
  25. treb11
    treb11
    Wilwood combination/proportioning/brake light switch valve. But for now its only on the Summit wish list.
  26. tjet
    tjet
  27. jimstro16
    jimstro16
    Pretty bad when I can't think of anything I need for my car that is ONLY $100
    -5 qts oil, some misc bolts, large cheese and pep and a sixer
  28. RMR&C
    RMR&C
    from NW Montana
    New battery.....remember when those were about $30 bux?
  29. gdub
    gdub
    A rebuilt steering box.
  30. Dennis D
    Dennis D
    Wiper motor. Although I will have to use some of next months allowance too. Dennis D
