Z a stock model a Frame?
Discussion in 'The Hokey Ass Message Board' started by Vintage Vandal, Feb 24, 2010.
  1. Vintage Vandal
    Vintage Vandal
    There's is a guy on ebay selling a "how to Z a frame" article from 1953. From what I can tell the frame looks stock . Not even boxed:eek:. I like everything about this idea but is it safe? Are there any pics of it done and done right? What do you guys think?[​IMG]
  2. Vintage Vandal
    Vintage Vandal
  3. shinysideup
    shinysideup
    from ruskin, fl
    What exactly is your question?
    It is very easy to use the search function to find a huge amount of info on that subject here.
    Please dont bump your own question every 10 minutes.
  4. HEATHEN
    HEATHEN
    from SIDNEY, NY
    So, what's to keep you from boxing it after you Z it?
  5. Vintage Vandal
    Vintage Vandal
    has anyone on the hamb ever "z"d a stock frame? The article on ebay looks like they just heated and bent the frame maybe.glad to know the self appointed hamb police are still around:rolleyes:
  6. 53sled
    53sled
    from KCMO
  7. dirty petcock
    dirty petcock
    Go buy the how to build a traditional Ford Hot Rod book. read it cover to cover. That's your best bet. These guys on here are going to be a$$holes to you with a open question like that.
  8. Vintage Vandal
    Vintage Vandal
  9. barry wny
    barry wny
    How I did it, some old pics.
    Lowered it the frame width, 4" in front. This also shortens it. Mock-up showed it needed more leingth, so the rear crossmember was un-riveted and a dog-leg piece was made to sweep back & up, mock-up show's you how much also. You can see the original rivet holes where the frame ended and straps added top & bottom after the plate made. Inside pic. shows the box plate, crush tube there is for gas tank mounting bolt.
    Drop in front also allows the wishbone mount to be at the bottom of the frame, not at the end of a 4" triangle plate hanging down to get the correct 6-9 degree caster.
    Bolt everything to the frame that will be on there before boxing and weld the nut or if thru-bolted a crush tube inside.
    A constant struggle to keep the rails straight while boxing, tried to curl in at the bottom in center near the end. That can be steered, lots of tacks and lots of cookie wheel slicing and re-tacking, it can be almost perfect with effort
    Bucket body is a sit-down-inside, so no channel.
    Radiator determined motor placement, that determined crossmember and cowl placement, my comfort + upholstery determined overall bucket leingth. With all that mock-up, I could design the rear kick-up piece that would fill the space between the end of the frame and the crossmember on spring.
    I haven't seen "the" book,
    http://s845.photobucket.com/albums/ab12/barrylm/Decorated images/
  10. Dreddybear
    Dreddybear
    I think that if you z a stock frame it should be boxed, unquestionably, at least where the z is...and if you're planning on more than a stock flatty then the whole thing should be boxed.
  11. Vintage Vandal
    Vintage Vandal
    Thanks alot for the pics. thats exactly what I was thinkin. How did you make the bends? did you have a jig made up? Was the build finshed? I like the original aspect of stock frame used.
  12. Vintage Vandal
    Vintage Vandal
  13. dsiddons
    dsiddons
    from Indiana
    Buy the book on How to build a traditional Ford Hot Rod by Tex Smith and Vern Tardel. It's a hot rod bible...
  14. srosa707
    srosa707
    from Sacramento
    With a tattoo like that, you'd think you might know?
  15. Fordguy321
    Fordguy321
    from Arizona
    thats not all bending! more like pie cutting to z frames
  16. barry wny
    barry wny
    Yeah, like Fordguy says, it's a matter of pie-cut, has to be done very carefully because a little wedge means a lot more than you think. I almost always use big sheets of cardboard when fabbing and try cutting the paper first and see what it looks like, and you could use the sucessful results as a pattern for marking steel. And like stated before, constantly mocl-up to make sure you don't end up with something that you can't use, like some R** R**s I have seen. More pics of the car here: http://s845.photobucket.com/albums/ab12/barrylm/
