zinc additive for engine oil
Discussion in 'The Hokey Ass Message Board' started by Oldkrow, Aug 14, 2011.
  1. Oldkrow
    Oldkrow
    So roday i Was buying rings for my 327, when the clerk informed me that in 2003 they stopped putting the zinc additive in motor oil because everthing is roller cam these days, which could translate to a deth sentence for your hydraulic valve system. You now need to add a zinc additive to your engine oil on your hydraulic set up to give it a lOng life! Ive worked for GM for 10 years and ive never heard of this...how about you???any thoughts?
  2. Matt Jones
    Matt Jones
    It is true. Not so much for the hydraulics of it but for flat tappet lobes and lifters. Its especially critical during cam break in but can't hurt to keep adding with each oil change. Learned this the hard way when i only got 10 minutes into a break in with a big solid lifter cam and it started chewing a lobe off
    Personally I've used crane cams stuff and Lucas brand stuff and they both worked. I know Comp cams and GM also make stuff
  3. Yup, it's a pain in the ***. I have used Zinc Hyperlube before, but it says right on the back that is is just an additive and does not actually contain zinc. I have heard people use diesel oil, but I have never tried this. Not sure what I should be running in my Y-Block???
  4. dep5
    dep5
    The Indiana Region of the Cl***ic Car Club of America and D-A Lubricant Company, Inc. are proud to present a revolutionary new motor oil specifically produced to reduce mechanical wear in your cl***ic car's engine.
    http://www.cl***iccarmotoroil.com/
  5. Can this product be purchased at any local autoparts stores? I will be in New York soon and would be interested in picking some up????
  6. Clik
    Clik
    After wiping a brand new cam in my small block I went looking for a zinc additive but it looks like most auto parts places quit carrying that as well. Then I found Amsoil's Z-Rod engine oil.
  7. thunderbirdesq
    thunderbirdesq
    I've used the Lucas or GM additive to break-in and then add half a bottle of STP, which contains zddp, with every oil change. Brad-Penn racing oil (the green stuff) has zinc in it too, got a buddy that uses it and so far so good.
  8. duke460
    duke460
    from Wisconsin
    There are quite a few posts on the subject. Lost 2 new engines in less that 50 miles. Flat tappet cam's are the issue. Convert to roller cam is available or I now use "Lucas oil breakin additive" on all new motors and a additive to my Y Block.
  9. Turbos10
    Turbos10
    from Texas
    GM EOS is also a good option. Last time I went to the dealer they had to dig some up and talked like they were not going to carry it any more so I bought all they had. But, I am sure some dealers still have it.
    Black_Sheep likes this.
  10. George
    George
    Spoosedly EOS was reformulated a few yrs ago, reportedly reduced zddp.. There's also ZDDPlus additive.
  11. Ole don
    Ole don
    Its really easy to buy the correct motor oil for an old engine. Look at the container. If it says on the bottle,"For gasoline engines", DONT BUY IT! There are oils from Shell, Pennsoil, Quaker State, Brad Penn, that are easily avaiable at every auto parts place, or truck stop I ever checked. Its made for diesel pickups. My flathead and my Y block get Shell Rotella 15W40. My Y block gets used in anger once a year, shifted at 6600 to 6800 RPMS. It runs great and beating the snot out of it for years has not bothered it.
  12. chubbie
    chubbie
    OOPS!!! the EPA now requires low emission diesel engines, hence it has been removed from diesel engine oils.
    Ive been useing ZDDPlus additive I hope it works, when do you find out?? to late?
  13. Hot Rod Bob
    Hot Rod Bob
    from T-ville Ky
    Try Brad Penn be sure to get PENN-GRADE 1 It has everything you need and it is ALL AMERICAN MADE no foreign crude!!!
  14. tommy
    tommy
    The after market is catching up with the need. I can't say if it works or not but it claims to replace the ZDDP that has been removed from the modern oils. At least this spells it out so there is no guessing.
    This is a moving target. 10 years ago it was a big deal on the flathead boards and we learned what oils kept it but many of those have changed their formulation and those recommendations are obsolete. They don't tell you when they change the formula.
    There are specialty racing oils that still have it today but they are pricey. I'm trying this for my new engine. I have had good luck with their products.
  15. Weasel
    Weasel
  16. coupemerc
    coupemerc
    Guess who's engine is pictured on the label?;)
  17. 61falcon
    61falcon
    valvoline vr1 oil contains zinc
    1971BB427 likes this.
  18. Buddy Palumbo
    Buddy Palumbo
    We use Brad Penn oil in ALL the cars that come through our shop (vintage/cl***ic British stuff ... flat tappet , etc.) . We're actually looking into becoming a dealer for the stuff .
  19. Okie Pete
    Okie Pete
    Low emissions for diesels means the sulfur content in the fuel has been lowered . Older diesel engines need sulfur to lube mechanical injectors .
    We run 15w40 diesel oil in every thing on the farm. Brigs auger engines , 390, 361 Fords ,slant 6 Chryslers , 292 ,327 Chevys so far no cam failure .
  20. George
    George
    The problem is...there are gallon jugs marked SM/CJ. To meet SM it has reduced zddp, & it would seem that CJ would have to be also for it to be marked that way.
  21. hombres ruin
    hombres ruin
    This has been so done to death... Easy use brad Penn oil it has the correct zinc. Period
  22. this right here (motor oil 101 through motor oil 109) should be required reading for all car junkies.
  23. dexleo2
    dexleo2
    I use Brad Pen for break in and then after the break in I use a ZDDP added to regular oil. I use this is my diesel pick and in my stock cars and have not had cam or lifter failer since I started adding Zinc and Phos to my engine oil, and since I have been adding it to my ford Diesel I have not lost an injector on it. So yes the EPA has reduced the levels of Zinc and Phos from todays motor oils to ensure the coverters in modern cars last 100,000 miles and it has hurt the hobbiest, car builder, ect, but just add it to your standard motor oil and all is great.
  24. banginona40
    banginona40
    Napa has a straight 30w that contains the necessary zinc? It is what I run in my coupe (327).
  25. zman
    zman
    from Garner, NC
    Lol, nope... 1st off the zddp in diesel oil has been lessened as well. Look for the ratings on it. 2nd, it's diesel oil and is formulated for diesels, the additive package is all wrong for regular gasoline engines.
    As Hombres Ruin stated, this has been done to death, a quick search would have netted a ton of relevant threads that have beaten this like the dead horse it is.
  26. NM Sandrail
    NM Sandrail
    Hi Everyone..
    Like my friend Okie Pete posted here...farm oil might be an answer. I use that Walmart Super Tech UNIVERSAL 15w-40 in my GMC truck... API Service Ratings on it is CI-4, CH-4, CG-4, CF-4, CF-4 SL, SJ
    I add a 1/2 quart of Lucas on top of that.. It was reported last year, that this oil was good for zddp.. But as you know, things change.. This oil is cheaper in price somewhat and says it is engineered for "Fleet and Farm" requirements.. It is hard to get premium oils out here, without giving up the "first born child".. It is 64 miles to closest WalMart for me.. and the auto stores are not any cheaper.. Farm stores might be a good source. No easy answers.. Stay cool today, everyone.. Already 100 in the shade :cool:here.. duane (NM Sandrail)
    PS.. This oil will be getting the old "Jimmie" to Joplin, later this week, for the HAMB Drags!
  27. 1949 caddyman
    1949 caddyman
    from arizona
    As I understand it the zinc was removed or lessened to keep from degrading the catalitic converter. Some diesel engines now have a cat, so could you ***ume that the zinc was also removed from oil for diesels?
  28. tommy
    tommy
    That is my understanding too. Of course that is why we lost the lead in 1974. The converters changed with OBDII also but the oil didn't change until recently. Many of the old posts on this subject contains out of date information due to the formula changes.
  29. zman
    zman
    from Garner, NC
    though a lot of them also discuss the changes as the spec was already in place, there just seemed to be some overlap with the old formulations still on the shelf and the new ones coming in.
  30. I've been adding ZDDP to straight 30 or 40w. in my pre 1981 engines for years.
    It helps prevent dry starts after they sit for a year (sometimes) without being started.
    It runs about $10 per bottle, delivered to my front door.
    http://www.zddplus.com/
    :cool:
