Zinc in oil
Discussion in 'The Hokey Ass Message Board' started by larry woods, Jul 12, 2011.
  1. larry woods
    larry woods
    from venice fl
    i recently stumbled upon a source for oil w zinc for flat tappets. For you in the north east Brad Penn has their specially labeled for flat tappets and very reasonably priced. is there anything new in the south east in particular gulf coast of florida? yeah i have done the research more than once. have used lucas. looking for something new? thanx for your help
  2. zman
    zman
    from Garner, NC
    Seriously you can just order it, Brad Penn is not only available in the north east. There should be someone in your area carrying it as well.
  3. MeanGene427
    MeanGene427
    from Napa
    Many speed shops stock Brad Penn, very easy to find, and you can order it direct if not. My neighbor has it stock in his shop in Napa, all they use for breakin
    IIRC, they have a dealer locator on their website
  4. Look at the Alliance Vendor list. Several sources for Brad Penn and others including ZDDPlus
  5. oldrelics
    oldrelics
    from Calgary
    Whats wrong with the Lucas?
  6. hotroddon
    hotroddon
    In the Car Craft article done by Jeff Smith, where they sent out oils to an independent lab, the Brad Penn stuff did not fair very well.
    The zinc content was 1,073 ppm and phosphorous was 931 ppm - some of the lowest of all tested
    The old SG rating for oil, before this all became a problem, was 1200-1300 PM - so you can see the Brad Penn didn't meet this - and this was their Break In Oil that is supposed to be a bit more fortified than the regular oil.
    Not looking for an argument, just p***ing along facts
  7. 59KUSTOM
    59KUSTOM
    Valvoline VR1 20W50 Part# VV211 OR 10W30 Part# VV205
  8. 1934coupe
    1934coupe
    Use it in my MG, its what John Gunn told me to use and I've had no probs.
    Pat
  9. MeanGene427
    MeanGene427
    from Napa
    Nice thing about VR-1 is your local Kragen usually has it on the shelf
  10. slammed
    slammed
    Man this again. There has to be (lab proven) a number of TOP 5 or so oil/ additive that do the job. Lets get the list and stash it in the archives.
  11. Special Ed
    Special Ed
    So, you are disputing an independent laboratory's factual findings? Do you have anything to back up your statement, or is that simply your opinion? :confused:
  12. hotroddon
    hotroddon
    Polaris Labs is highly respected in the oil field and they are the lab that was used. Sorry that your cynicism gets the better of you :eek:
  13. bigalow1
    bigalow1
    from 496 C.I.
    I AM with you slammed. I posting a thread on what oil to use with my Flat Tappet Cam andafter reading all the dif replies I CLIMBED up on the ROOF!!
    Then I climbed back down drained 10 quats of Royal Purple(not nec good for flat tappet cams) and replaced with BRAD PENN!!!
    NOW Here I go reading again??? CCraft says Brad Penn doesn't have enough Zinc!! SHUT THE FRONT DOOR!
  14. TORCO is an excellent source for Zink protection and they make an additive that will bring the levels up to where you need it with any of your favorite brands.
  15. Gman0046
    Gman0046
    One thing to remember in the use of additives is too much zinc is not a good thing either. FYI Valvoline has an online coupon for $15 off on the purchase of their VR-1 synthetic oil.
  16. bigalow1
    bigalow1
    from 496 C.I.
    I thought Brad Penn was specifically for engines reqiuring Zinc??? WTH.
    Is there merit to the Car Craft article??
    I havent wiped my Mech Cam yet?
    I just want to buy Oil and not Mix
  17. larry woods
    larry woods
    from venice fl
    thanx for the input!
  18. burnin53
    burnin53
    from cuba,n.y.
    Was this Brad Penn 20w50 racing oil,though? I think this is supposed to have more zinc than their other oils. It's what I've been using lately.
  19. hotroddon
    hotroddon
    It was their break-in oil which is advertised as being higher in Zinc and Phos.
  20. Ole don
    Ole don
    I decided to choose an oil I can buy inexpensively over the counter in the parts of the country where I drive. The oil I picked is Shell Rotella. It can be found anywhere in 15W40, if you look around, you can find 10W30. Available at any farm store, O'Rielly, Auto Zone, Wall Mart, and every truck stop I ever saw. It is meant for diesles, go where diesel fuel is sold.
  21. bigalow1
    bigalow1
    from 496 C.I.
    I read they backed off on the Zinc because of emissioms w Rotella????
    Used to be good-I was reading again
  22. oldblue1968chevy
    oldblue1968chevy
  23. chop32
    chop32
    Rotella and Dello are diesel oils. Newer Diesels now have particulate filters which become clogged from the ingredients in the older oil, so both brands have been re-formulated with a lot less Zinc and Phos. Diesel oils are also for lower rpm engines and may not have the anti-foaming characteristics of a high performance gas engine oil...probably alright for a late model roller cammed stocker, but not for something you are going to beat on.
  24. bigalow1
    bigalow1
    from 496 C.I.
    reading isn't for losers afterall. All the reading I do paid off-I was RIGHT!!!!
    NOW WHAT ABOUT BRAD PENN???? HELP
  25. Gman0046
    Gman0046
    According to oldblue's link above on post #23, Brad Penn is OK. I've read previously the Brad Penn 10W-30 oil contains almost 1500 ppm ZDDP. Thats what I use. Use your Brad Penn and don't worry.
    That new Rotella is a Gotcha as it no longer contains a high Zinc level.
  26. kkustomz
    kkustomz
    from Texas
    when they lowered the zinc content in the rotella , they took, "advanced soot control" of the front of the jugs, about 8 months ago if i remember right
  27. bjs531
    bjs531
    I have had pretty good luck with the high zinc Amsoil. Best part is that my neighbor sells it so I only have to wander across the street to buy it.
  28. no55mad
    no55mad
    Check out the information on the Alliance Vendor site, product is sold here www.zddplus.com May be the cheapest and best way to go - even Big Daddy Don G. likes the product.
  29. larry woods
    larry woods
    from venice fl
    The 28 responses is the reason i posted in the first place. as i said i did the research and wanted to know what was currently going on so i came to the best source of current info that i know. Based on Brad Penn info their 10-30 is higher zinc than 20-50. roughly 1200 vs 1000 ppm (min). again thanx everyone for their input we all need to keep current!
  30. bigalow1
    bigalow1
    from 496 C.I.
    How much zinc do you need for a flat tappet cam set-up???
    ****/ppm?
