Zip,s high raiser water pump
Discussion in 'The Hokey Ass Message Board' started by 32highboy54, Jul 13, 2011.
  1. 32highboy54
    32highboy54
    from southport
    Need some advice. I am building a 32 ford highboy with a mild sbc. I see cars running zip,s high raiser water pumps for better cooling. I want a cooling running engine here in the south,but to dish out $250 for one one these hurts the wallet. I will if it will prevent over heating. What do you guys think?
  2. How fat is your wallet? Lots of old jalopies have run without them but if your wallet will sustain it why not?
  3. Mpls 40
    Mpls 40
    another option is to run an electric fan.
  4. 32phil
    32phil
    from New York
    I have one on the 265 in my 32 two door. So far so good. The stock set up puts the w/p & fan way down low. The fan has to be real small too. I'm putting one on a 241 Red Ram Dodge Hemi. We'll see how that goes.
  5. Run a quick search, this has been covered many times and there is a ton of good tech on them. I found a used one from a HAMBer here.
  6. 31Apickup
    31Apickup
    The main purpose of running one is that it places the water pump higher so you can runa decent size mechanical fan. You are limited to a small diameter fan or electric fan with the stock water pump location.
  7. chrisntx
    chrisntx
    from Texas .
    If only the search function worked on this forum you could find the post where a guy made his own
    The only cost was for the 6 cylinder water pump
  8. Last edited: Jul 13, 2011
  9. chrisntx
    chrisntx
    from Texas .
  10. Yeah, but I gotta admit, AFTER I ran the search I realized I had already bookmarked it! DOH!!!!!:eek:
  11. 1gearhead
    1gearhead
    There is another company that makes a high rise water pump, Snow White. Have used the one they make successfully a couple of times. They have a web site.
  12. Deuce Roadster
    Deuce Roadster
  13. pan-dragger
    pan-dragger
    I think they are worth the money, just to have a mechanical fan. I'm not one for electrical **** hanging on my radiator. I run one on my roadster with a slightly warmed ZZ4 and it works great along with a Walker radiator.
  14. Deuce Roadster
    Deuce Roadster
    You MUST be reading some old threads ...
    I have not even posted 20 times total in the last week :)
    Folks keep asking about the ZIPS ... and not using the search function ...
