Technical Zips SBC Water Pump Riser.
Discussion in 'The Hokey Ass Message Board' started by Britdragster, Sep 3, 2025.
Tags:
  1. Britdragster
    Britdragster
    Hi all. I'm on the look out for a Zips water pump riser kit for a chevy small block in my 29 Tudor. I'd like to stay mechanical if possible, hence my request. I've done a google search and the two places that seemed to stock them don't have one and have no idea when they'll be back in stock. So, to that end I thought I'd cast my net far and wide and just hope that someone on here has one that they're not going to use. The only snag is I'm in England, so they must be willing to post it to me, on my dime of course. So, please reply if you have one or know where I can find one. Many thanks for any help offered. Cheers n beers. Roger.
  2. THE-SYNDICATE
    THE-SYNDICATE
    Britdragster likes this.
  3. TCTND
    TCTND
    If you can't find one, there is an alternative solution that may (or may not) work. If there is room for a fan in the stock location you could make a shroud to fit the radiator. All the air would have to p*** through the rad and the low fan location wouldn't matter.
  4. You should try posting in the Wanted add section on here. They actually work very well.
  5. HOTRODPRIMER
    HOTRODPRIMER
    I have used zips risers on 4 different 32 fords and can ***ure you they work great, they center a mechanical fan in the center of the radiator and my cars never run hot no mater how bad the traffic is. HRP
    Britdragster and 19Eddy30 like this.
  6. Ryan
    Ryan
    ADMINISTRATOR
    Please repost this in the wanted section.
