Zips water pump model a
Discussion in 'The Hokey Ass Message Board' started by cessnapilot36, Dec 20, 2010.
  1. cessnapilot36
    cessnapilot36
    Has any one used a zip water pump riser on a chevy 350 with three two's and air conditioning ? Do you have any pictures ? Will it work , Thanks
  2. Von Rigg Fink
    Von Rigg Fink
    from Garage
    On your 3x2 manifold , do you have the fill tube?
    if so it can be an obstuction, for the raised pump
    I sold a zips not too far back, it had provisions for alternator and ac pump..seems to me things could get tight up front with all that, not sure on how close to the front carb or any interfearence, never got that far with it before i decided against using it.
  3. I wish I would had been on that, I need one!
  4. cessnapilot36
    cessnapilot36
    Yea Ive got the oil fill tube its hitting the riser and the water neck has only about a 1/16 clearence waiting on my a/c kit to come in to see how the compressor is going to look but yes its starting to look tight.
  5. lurker mick
    lurker mick
    My oil fill tube had to be cut and angled to miss the front carb float bowl, and sits about where the a/c compressor would.
    Mick
  6. lurker mick
    lurker mick
    Her's a photo if it helps.
    Mick
  7. mr.chevrolet
    mr.chevrolet
    i recently met Zip and toured his shop. he just might be a mechanical genius.
  8. flatmotor40
    flatmotor40
    from georgia
    I have a snow white riser and no problem
  9. Von Rigg Fink
    Von Rigg Fink
    from Garage
    could you post a picture up to show how it doesnt interfear with the front carb or fill tube..
    this was one of the main reasons why i opted out of using a zips, but never thought it would be different with the snow white riser..
    thanks
