zips water pump riser alternator question
Discussion in 'The Hokey Ass Message Board' started by 1929Ahotrod, Aug 17, 2012.
  1. 1929Ahotrod
    1929Ahotrod
    thanks for everything
  2. do you have the correct water pump and crankshaft pulleys?
  3. HOTRODPRIMER
    HOTRODPRIMER
    Did you use the 6 cylinder water pump? HRP
  4. wayne-o
    wayne-o
    As 36-3Window said. I used a standard Delco and everthing lined up fine once I got the correct water pump pulley. The number for the one Zip's gives you is available from a GM dealer but for like $90.00. I bought an aftermarket chrome one I found online from a place in California for like $25 and sandblasted and painted it. PM me and maybe I can find the receipt this evening and get you the P/N and the contact info.
  5. Does the crank and water pump line up ?.
  6. it's not that i doubt you have a problem , just not sure what it is. i have never used one , but have always heard good things about them. there has to be something we are missing about your setup
  7. 1929Ahotrod
    1929Ahotrod
    all better
  8. HOTRODPRIMER
    HOTRODPRIMER
    The Zips riser calls for a 6 cylinder water pump,not a sbc water pump.
    these are the correct pulleys for the zips.HRP
    Lower pulley Chevrolet # 3850838
    Pump pulley # 3995642
  9. 1929Ahotrod
    1929Ahotrod
    all done
  10. You did.:rolleyes:
    Search Zips here. There a LOT of other tips from some of these guys that have had many of thier setups.
  11. Deuce Roadster
    Deuce Roadster
    I have been using the ZIPS raised water pump risers since the late 1970's.
    I have never had the line up issue you are having. :) I do have a Power Master alternator on my 32 3W ... but just a regular old everyday 1970 Chevelle alternator that fits perfect.
    I suggest another alternator. I have used ones off a early Vega with great sucess.:D
  12. Here's where I was throw - sorry you couldn't get your serious answers immediately
    Nobody jumped your *** for no intro either.
    no longer lines up with the waterpump pulley or the crankshaft pulley .
  13. Bears38
    Bears38
    I bought a used zip's riser and am gathering parts to install on my '38 . I noticed there are two types of clutch fans - one that is temp controlled and one that is speed controlled . Which one would be the better one ? I am planning on having air conditioning if that matters .
  14. Da Tinman
    Da Tinman
    temp controlled is the better of the 2.
    RIP DR.
